- 5 May 2006
Yeni CB1300 yakında yollarda 119 HP 23-24 Bin ytl civarında .Türkiyeye şimdilik 10 adet giriyor.Bilgilerinize sunulur...
Technical Specifications CB1300 (ED-type);
# Engine Type - Liquid-cooled 4-stroke 16-valve DOHC inline-4
# Displacement - 1,284cm3
# Bore x Stroke - 78 x 67.2mm
# Compression Ratio - 9.6 : 1
# Max. Power Output - 85kW/7,500min-1 (95/1/EC)
# Max. Torque - 117Nm/5,500min-1 (95/1/EC)
# Idling Speed - 1,000min-1
# Oil Capacity - 4 litres
Fuel System;
# Carburation - PGM-FI electronic fuel injection
# Throttle Bore - 36mm
# Aircleaner - Dry, cartridge-type paper filter
# Fuel Tank Capacity - 21 litres (including 4.5-litre warning light reserve)
Electrical System;
# Ignition - System Computer-controlled digital transistorised with electronic advance
# Ignition Timing - 5° BTDC (idle) ~ 46° BTDC (3,500min-1)
# Sparkplug Type - DPR8EA9 (NGK); X24EPR-U9 (ND)
# Starter - Electric
# Battery Capacity - 12V/14AH
# ACG Output - 420W/5,000min-1
# Headlights - 12V, 55W x 1 (low) / 60W x 1 (high)
Drivetrain;
# Clutch - Wet, multiplate with coil springs
# Clutch Operation - Hydraulic
# Transmission Type - 5-speed
# Primary Reduction - 1.652 (76/46)
# Gear Ratios - 1; 3.083 (37/12), 2; 2.062 (33/16), 3; 1.545 (34/22), 4; 1.272 (28/22), 5; 1.130 (26/23)
# Final Reduction - 2.167 (39/18 )
# Final Drive - #530 sintered link chain
# Frame Type - Double-cradle; steel tube
Chassis;
# Dimensions - (LxWxH) 2,220 x 790 x 1,120mm
# Wheelbase - 1,510mm
# Caster Angle - 25°
# Trail - 99mm
# Turning Radius - 2.7m
# Seat Height - 790mm
# Ground Clearance - 135mm
# Dry Weight - 224kg (*230kg)
# Kerb Weight - 252kg (F: 124kg; R: 128kg) (*258kg (F: 126kg; R: 132kg))
# Max. Carrying Capacity - 188kg
# Loaded Weight - 452kg (F: 176kg; R: 283kg)
Suspension;
# Type - Front, 43mm cartridge-type telescopic fork with adjustable compression and rebound damping, 120mm axle travel
# Rear - Dual conventional dampers with 5-step adjustable spring preload, 116mm axle travel
Wheels;
# Type - Front, U-section 5-spoke cast aluminium
# Rear - U-section 5-spoke cast aluminium
# Rim Size - Front, 17M/C x MT3.50
# Rear - 17M/C x MT5.50
# Tyre Size - Front, 120/70 ZR17M/C (58W)
# Rear - 180/55 ZR17M/C (73W)
# Tyre Pressure - Front, 250kPa
# Rear - 290kPa
Brakes;
# Type - Front, 310 x 4.5mm dual disc with 4-piston callipers (*ABS) and sintered metal pads
# Rear - 256 x 6mm single-piston calliper disc (*ABS) with sintered metal pads
Bundar CB1300 Super Four (Naked Model) ve CB1300 Super Bol D'or (grenajlı model) 'dir. Üretimi uzun yıllara dayanmaktadır. Japonya için 400cc'lik modeller üretilmekte ve bayanlar tarafından tercih edilmektedir.
Dikkat çekici kuyruk tasarımı,sıvı soğutmalı sıra 4 silindirin ürettiği tork ve yıllardır süre gelen çizgisiyle oldukça beğeni kazanan bir motordur.
Ülkemize gelecek olan model ise son dönemde Avrupa pazarı için ABS eklenmiş versiyon olan CB1300SF ABS modelidir.
CBF Türkiye sitesinden alıntıdır...
türkiye ye geldi burdan bakabilirsiniz fiyatı 22.490 ytl
http://www.honda.com.tr/motosiklet/content/modeller/naked/cb1300.htm
Fuel System;
Electrical System;
Drivetrain;
Chassis;
# Trail - 99mm
Suspension;
Wheels;
# Rear - 290kPa
Brakes;
