Yeni 2005 Model R6
16 Haz 2004
Yeni R6 2005 te YZF-R46 modeli olarak piyasaya çıkacak
Engine
Engine type 4-stroke, forward inclined, parallel 4-cylinder, 16-valves, D0HC
Engine cooling Liquid cooled
Displacement 600cc
Bore x stroke 65.5mm x 44.5mm
Compression ratio 12.4:1
Maximum power With direct air induction: 92.7kW (126 HP) @ 13,000rpm / Without direct air induction: 88.2kW (120 HP) @ 13,000rpm
Maximum torque With direct air induction: 68.5Nm (6.99 kg-m) @ 12,000rpm / Without direct air induction: 66.4Nm (6.78 kg-m) @ 12,000rpm
Lubrication system Wet sump
Carburettor/Fuel supply Suction piston type electronic fuel injection
Clutch type Wet multiple-disc
Ignition system DC-CDI
Starter system Electric
Transmission system Constant mesh, 6-speed
Final transmission Chain
Fuel tank capacity 17 litres (3.5 litres)
Oil tank capacity 3.4 litres
Remark 1 Carbon slip-on exhaust with solo bracket
Chassis
Chassis: Aluminium die-cast Deltabox III
Front suspension system Up-side-down telescopic fork
Front travel 120mm
Rear suspension system Swingarm (Link suspension)
Rear travel 120mm
Front brake Dual discs, Ø 310mm
Rear brake Single disc, Ø 220mm
Front tyre 120/70 ZR17 (58W)
Rear tyre 180/55 ZR17 (73W)
Dimensions
Length 2,045mm
Width 690mm
Height 1,105mm
Seat height 830mm
Wheel base 1,385mm
Minimum ground clearance 135mm
Dry weight 163 kg
Admin
Yönetici
14 Nis 2003
Yamaha MT-09 Tracer
Bu modelde yeni mi cıkardi bilen var mı?
Yamaha MT1
1 Haz 2004
üzerindeki makine warrior'un makinesine benziyo ama hoş olmuş..
1 Mar 2004
HAYALLERİM , AŞKIM ve HAYATIM = R6
(n)
30 Eyl 2004
Yamaha MT1 i tercih ederim.. Çok güçlü ve özgüvenli duruyor..
16 Haz 2004
o ağır makina yı kim getirir ki türkiyeye
siz ona binene kadar o size biner walla
