- 12 Ara 2004
Arkadaşlar ben TVS FİERO F2 almayı düşünüyorum.
Aradığım makina (2.300 YTL
) 2 milyar 300 milyon civarında bişey di.
bu motorun fiyatı 2 300.
Özellikleri şöyle:
Type Single Cylinder, 4-Stroke, Air cooled OHC
Displacement 147.5cc
Compression Ratio 9.4:1
Maximum Power 12 bhp (8.95 kW) @ 7000rpm
Maximum Torque 10.5Nm @ 6500rpm
Maximum Speed 100 Km/h
Transmission 4 Speed
Overall Length : 2020 mm
Overall width : 750 mm
Overall Height : 1110 mm
Ground Clearance :155 mm
Kerb Weight :124 kg
Wheel Base :1270 mm
Front Tyre Size : 2.75*18
Rear Tyre Size : 90/90*18
Front Brake : 240 mm Disc
130 mm Drum ( optional)
Rear Brake : 130 mm Drum
Ignition System : Digital CDI
Head Light : 12V 35/35 W/Halogen
Tail/ Brake Light : 12V 5/10 W
Battery Capacity : 12 V 2.5 Ah - Kick Start
Fuel Tank ( including reserve) : 13.0 Litres
Reserve : 2.0 Litres
Front : Hydraulically damped telescopic suspension
Rear : Rectangular box swing arm
5- step adjustable shock absorber
Triple rated spring
http://www.tvsfiero.com/ site adresi bu.
Alternatif önerileriniz varsa bekliyorum.. Sizce motor nasıl..
Sanki rpm i düşük gibi geldi bana.
Özellikleri şöyle:
Kerb Weight :124 kg
Wheel Base :1270 mm
Triple rated spring
