suzuki DR650 hakkında bilgi paylaşımı
1 Eki 2006
suzuki dr650 nin hangi modeli ve hangi yılda imal edilmişin ögrenmek istersen
http://www.motorcyclespecs.co.za/bikes/suzuki%20%20%20.htm
bir örnek 1990 model dr650 dakar
Model
Suzuki DR 650R Dakar
Year
1990
Engine
Air/oil cooled, four stroke, single cylinder. SOHC, 4 Valve per cylinder.
Capacity
640
Bore x Stroke 95 x 90.4 mm
Compression Ratio 9.7:1
Induction
40mm flat side BST40 Mikuni
Ignition / Starting
Digital / kick
Max Power
45 hp 32.8 kW @ 6800 rpm ( 41.1hp @ 6500 rpm )
Max Torque
57 Nm @ 5000 rpm
Transmission / Drive
5 Speed / chain
Front Suspension
Full Floater swingarm, gas/oil damped
Rear Suspension
Single 280mm discs 2 piston caliper
Front Brakes
Single 280mm disc 2 piston caliper
Rear Brakes
Single 230mm disc 2 piston calipers
Front Tyre
90/90-21
Rear Tyre
120/90-17
Dry-Weight / Wet-Weight
155 kg / 168 kg
Fuel Capacity
21 Litres
Consumption average
19.8 km/lit
Braking 60 - 0 / 100 - 0
14.2 m / 42.0 m
Standing ¼ Mile
13.9 sec / 143.2 km/h
Top Speed
162.7 km/h
16 Ocak 2006
ee ben geçen günler biyerde rastladım 1985 model DR650 ayaklıgı olsa hala dimdik ayakta durcak...bu arada verdiğin site güzelmiş ben anca DR650 DR350 DR125 birde yeni cıktı işte DRz400 ü tanıyodum..bu iyi oldu
