Mz Rt 125
7 Eyl 2007
MZ durmuyor
23 May 2007
Resim güzel ama sadece resim bişey ifade etmiyor bence bişiler eklemek gerek dimi:)
silindir hacmi:124.00 cc,tek silindir,4 zamanlı,9000 devirde 11 hp güç üretiyo olması,133 kg ağırlığa sahip olması vs. bilgiler fena değil yani haa bi de 12.5 litre yakıt deposu var...:cat:
15 Eyl 2007
makinenin tipi güzel ama acaba kullanan arkadslarımız var mı?varsa performansı hakkında bilgi verirlerse güzel olur......
14 Eyl 2006
ybr'yi yer mi bu:p
(25karakter)
25 kere yer bence:cat: :cat:
General information
Model: MZ RT 125
Year: 2005
Category: Sport
Rating: 73.6 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 124.00 ccm (7.57 cubic inches)
Engine type: Single cylinder
Stroke: 4
Power: 11.00 HP (8.0 kW)) @ 9000 RPM
Torque: 11.70 Nm (1.2 kgf-m or 8.6 ft.lbs) @ 8500 RPM
Valves per cylinder: 4
Fuel control: DOHC
Transmission type
final drive: Chain
Physical measures
Dry weight: 133.0 kg (293.2 pounds)
Seat height: 770 mm (30.3 inches) If adjustable, lowest setting.
Overall height: 2,004 mm (78.9 inches)
Wheelbase: 1,355 mm (53.3 inches)
Chassis and dimensions
Front suspension: Telescopic fork
Rear suspension: Rear monoshock
Front tyre dimensions: 110/70-17
Rear tyre dimensions: 130/70-17
Front brakes: Single disc
Rear brakes: Single disc
Speed and acceleration
Top speed: 108.0 km/h (67.1 mph)
Power/weight ratio: 0.0827 HP/kg
Other specifications
Fuel capacity: 12.50 litres (3.30 gallons)
Reserve fuel capacity: 3.60 litres (0.95 gallons)
Further information
Parts and accessories Check out parts and accessories from our partners. MZ RT 125 accessories
Ask questions Join the 05 MZ RT 125 discussion group
Insurance, loans, tests Search the web for dealers, loan and insurance costs, tests, customizing, etc.
Related bikes List related bikes for comparison of specs
kusura bakmayın yabancı dile biraz yabancıyım
1 May 2006
evolution denilen şey bu olsa... güzel mak. yapmışlar
11 May 2006
mz in orjinalliği burda işte bi şu alete bakın bide ybrye. al bi mz dünyayı gez. kral marka. :)
7 Ağu 2007
motor çok iyi, yanlış görmüyosamda sıvı soğutmalı, sıvı soğutmalı motorlara zaafım var.
24 Tem 2007
harbi namyak makine yapmışlar ilk görüyorum acep türkiyede varmı bu aletten
18 Ocak 2007
Bı kere YBR ye gore daha guzel bır tıpı var daha yenılıkcı sonra Sıvı sogutmalı sonra arka amortısor ortada tek cok guzel ı goruntu vermıs sonra Cıft dısk fıren de cabası bence enfes bı tasarım YBR cortlar bunun yanında...
