Daha fazla resim ve 1000 cc. bir motoru varmış. Dönüş beni de meraka düşürdü ama adamlar dönüyor yatıra yatıra. Resimler linklerde.
http://www.peraves.ch/ECO_03.htm
http://www.peraves.ch/Startbild.htm
Super - Turbo - ECO Modelinin Teknik özellikleri
SPECIFICATION PERAVES W-18K12T SUPER-TURBO-ECOMOBILE 1200ccm*
VEHICLE BODY & STRUCTURE
Composite-Monocoque made from KEVLAR**& glass-weave bonded by ARALDITE*** Epoxy resin, reinforced by roll-,crash- and lateral protection-bars, engine mount and steering head in argon-arc-welded aviation grade steel.
Front suspension by telescopic fork held by carbon reinforced fittings.
BMW-Monolever in rear with Oehlins-shock-strut. A/C-grade steel supporting roll axles, gull wing door with integrated sun roof opening to the left.
Tinted acrylic plexi glazing , ECE-43-specs windshield on option.
200 l. Baggage compartment in rear, SAE-confomal-seat-belt-hardpoints, uni-customized paint.
MECHANICS
4-cylinder-BMW-K-engine 1171 ccm with IHI-turbo, intercooler & liquid cooling.
Reinforced dry-monodisc-clutch. PG-gearbox with 4 forward speeds and electrically unlockable reverse,electric gear shift, shaft drive.
3 SICOM brake discs with forced internal aeration and 4-piston hydraulic calipers.
Fully integrated electronic ABS-system. Mechanical parking brake on rear wheel. ASR anti-spin engine torque control.
Aluminium 5-spoke-wheels MT-H2-type 17x3.50" and 17x5.00" or 17x5.50". ZR-TL-low-cross-section sport tyres.
Computer-supervised electrical SERVO-stabilizer-system with manual lowering backup.
EQUIPMENT & ACCESSORIES
2-color leather seats with 3-point automatic safety belts. Interior padding in Alcantara and grey velours, black noise suppressing carpets. Self-locking baggage compartment cover with integrated headrest. Complete instrumentation. Heating- and ventilation-system with 3-stage-blower & mirror -defogging, summer ventilation and winddeflector. BECKER TRAFFIC PRO GPS. CD-Audio, AIRSTAB ect. on option.
OPERATION
Motorcycle-type handlebars with extended functions. Clutch pedal left, gear- and supporting-roll-switches left, integrated brake operation by pedal right, aux-brake lever and twist-throttle on handlebar right.
SOME FIGURES
Empty weight 455 kgs (1035 lbs). Fuel Tank 47 ltrs (12,4 USG). Max. drive weight 685 kgs (1510 lbs).
Dimensions l = 3.70 m h = 1.48 m w = 1.47 m . Service every 25.000 kms. Warranty 1 year, on structure 25 years.
Engine power output 140kW/190HP at 8000/min, max. torque 179Nm/6000/min turbocharged to 0,75 bar, controlled by wastegate and bypass.
Accel. 0-100 km/h 4,9 sec. Top speed 315 km/h (195 MPH +).
Stop distance 100-0 km/h 43 m. Turning circle btn. walls 8.5 m
Consumption ISO 7118: Lead free premium gas.
4.60 l/100km at constant 90 km/h (52 MPG)
5,45 l/100km at constant 120 km/h (43 MPG)
