ingilizce motor sınavı
12 Nis 2004
İngiltere'de yapılan motor sınavı soruları
6. 14. 23 ve 35 soruların şekillerini buraya yansıtamadım ama yine de İngilizce sorunu olmayanlar için yararlı olabilir.. Best regards.
Cevaplar ekte ..
1) How many yellow lines would you expect to find painted over the kerb,
when the nearby time plate on the lamp-post reads 'NO LOADING AT ANY TIME'. Is it ?
A - None
B - One
C - Two
D - Three
2) The national speed limit on a single carriageway is:-
A - 40 mph
B - 50 mph
C - 60 mph
D - 70 mph
3) Use fog lights when visibility is seriously reduced.
Generally when visibility is less than?
A - 50 metres
B - 100 metres
C - 200 metres
D - 300 metres
4) You are following a large articulated vehicle. It is going to turn left into a narrow road.
What action should you take?
A - Overtake as it starts to slow down
B - Stay well back to give it room
C - Get closer in order to pass quickly
D - Pass on the left as the vehicle moves out
5) What is the safest way to brake?
A - Brake hard, put the gear lever into neutral and pull your handbrake on just before stopping.
B - Brake lightly, then harder as you begin to stop then ease off just before stopping
C - Put the gear lever into neutral brake hard then ease off just before stopping
D - Brake lightly, at the same time push your clutch pedal down and pull your handbrake on as you stop.
6) Where would you see this sign?
A - On a school crossing
B - Outside a school gate
C - On a bus carring blind people
D - On a bus carrying children
7) Why should tyres be kept at the right pressure the manufacturer tells you?
A - To keep the car the right height above the road
B - To make the ride more comfortable
C - To stop the car from leaning to one side
D - To prevent the car from skidding
8) You are first to arrive at the scene of a road-traffic accident involving 3 cars.
It is dark and raining. What should you do first?
A - Drive on to the next phone, to ring for help
B - Stop and switch off any engines and warn oncoming traffic
C - Stop and get the injured out of their cars to safety
D - Stop the next vehicle that comes along and ask if they are a Doctor
9) Hazard warning lights should be used when vehicles are:-
A - Being towed along the road
B - Faulty and moving slowly
C - Broken down and causing an obstruction
D - Reversing into a side road
10) Where should you take particular care to look out for motorbikes?
A - At junctions
B - On one-way streets
C - At traffic lights
D - At roundabouts
11) It is important to wear suitable shoes when you are driving. Why is this?
A- To enable you to walk for assistance if you break down
B - To enable you to make quicker gear changes
C - To maintain safe control of the pedals
D- To prevent wear on the pedal rubbers
12) You are using the Motorway at night. Always have your headlights on unless:-
A - The motorway is lit
B - There are vehicles ahead of you
C- You are travelling less than 50 mph
D - Your vehicle has broken down on the hard shoulder
13) What traffic shape signs are mostly prohibitive?
A - Circular
B - Triangular
C - Rectangular
D - Square
14) What does this sign mean?
A - No entry to cyclists and pedestrians
B - Cycle route ahead
C - Cyclists and pedestrians only
D - Cyclists and pedestrians in the road ahead
15) Which statement is correct regarding steering?
A - You must keep both hands on the steering wheel at all times
B - You can place your hands at any position as long as it is comfortable
C - When going around corners, it's best to cross your hands
D - To keep good control you should 'feed' the wheel through your hands
16) You are sensible enough to carry a red warning triangle in your car.
Where do you place the triangle if you break down on a Motorway?
A - Right at the back of the car
B - You should never use them on Motorways
C - 45 metres behind the car
D - 150 metres behind the car
17) Any driver who accumulates 12 penalty points within a three-year period
must be disqualified from driving.
How many penalty points do you receive for 'running' a red light?
A - 2 points
B - 3 points
C - 4 points
D - 6 points
18) In WET road conditions the minimum distance you should leave
between you and the vehicle in front should be at least?
A - 2 second gap
B - 3 second gap
C - 4 second gap
D - 10 second gap
19) What colour studs would you expect to be used across lay-bys on major roads?
A - Green
B - Red
C - White
D - Amber
20) Which of the following CAN travel on a motorway?
A - Vans
B - Cyclists
C - Tractors
D - Learner drivers
21) When you are accelerating too harshly your car starts to skid.
What should you do?
A - Steer into the skid
B - Ease off the gas pedal
C - Make the car go faster
D - Brake hard
22) What should you do when waiting to emerge from a junction,
a vehicle is approaching from your right signalling left.
A - Move off quickly
B - Move off because the vehicle is turning left
C - Apply the handbrake
D - Wait to see if the vehicle turns left into the road
23) If you are towing a trailer, what is the maximum speed you are
allowed to drive on a national speed limit Dual Carriageway?
A - 40 mph
B - 50 mph
C - 60 mph
D - 70 mph
24) In which circumstances may you flash your headlights?
A - To thank other drivers
B - To warn other drivers of your presence
C - To signal to a pedestrian
D - To alert other drivers to a police speed trap ahead
25) The approach to a pedestrian crossing is marked with:-
A - Yellow Lines
B - Zig-Zag Lines
C - Hazard Lines
D - Double White Lines
26) What do child locks in a vehicle do?
A - Stop children from opening rear doors
B - Lock the seat belt buckles in place
C - Lock the rear windows in the closed position
D - Stop the rear seats from tipping forwards
27) When driving on a motorway, when should you indicate to change lanes?
A - You should indicate to pull out but not on returning to a lane
B - You only need to indicate when there are other drivers behind you
C - You do not need to indicate when you are on the motorway
D - You should always indicate to change lanes
28) A flashing motorway sign reads 'FOG' on a apparently clear road.
What does this tell you?
A - Someone forgot to turn the sign off
B - The sign has a fault
C - Turn your rear high intensity fog lights on
D - There is fog up ahead
29) Which one of the following is NOT affected by alcohol ?
A - Reaction time
B - Perception of colour
C - Judgement of speed
D - Co-ordination
30) When may you NOT overtake on the left?
A - On a free flowing motorway or dual carriageway
B - When the traffic is moving slowly in a queue
C - In a one-way street
D - When the car in front is signalling to turn right
31) The choke on a petrol engine motor car is a device which:-
A - will help start a hot engine
B - reduces the amount of air/fuel mixture
C - restricts fuel flow and prevents flooding the carburettor
D - will help start a cold engine
32) What extra signal can you give at a zebra crossing when you stop to let someone cross?
A - Wave to the pedestrian to tell them its safe to cross
B - An arm signal to tell the vehicles behind that you are slowing down
C - A brake light signal
D - Flash your headlights to tell others you have stopped
33) What should you do about a frayed seat belt?
A - Get it replaced
B - Tape the bad piece and sew it up
C - Remove the belt altogether
D - Nothing, because the MOT doesn't cover seat belts
34) When driving in snow, how can you avoid wheelspin?
A - Brake gently and repeatedly
B - Stay in second gear all the time
C - Use only your handbrake to make the vehicle stop
D - Drive in a higher gear as possible
35) What does this traffic sign mean?
A - Use the near-side (left) lane
B - Roundabout ahead
C - Special diversion route
D - Diversion route to the football ground
35 Theory Test Answers-Bonus
1. C 13. A 25. B
2. C 14. C 26. A
3. B 15. D 27. D
4. B 16. B 28. D
5. B 17. B 29. B
6. D 18. C 30. A
7. D 19. A 31. D
8. B 20. A 32. B
9. C 21. B 33. A
10. A 22. D 34. D
11. C 23. C 35. C
12. D 24. B
31 Ocak 2005
Benim bu kadar ingilizcem olsa uzay mekigi discovery in ehliyetini alirdim dimiya
muhaaaaahahahaaa :geek:
28 Ağu 2004
adamların kurallarıda değişik sorular tamamda cevaplar...!!!1
muhahaha biraz zor oldu yusuf ettim :giggle:
