- 26 Mar 2007
Honda VFR1200 X Crosstourer
Bugün itibariyle ulaşabildiğim bazı bilgiler ve fotoğraflar aşağıda. Model ile ilgilendiğim için bir başlığı olmasını istedim. Kullanıcılar deneyimleri hakkında bizleri de bilgilendirirlerse seviniriz.
Teknik Özellikleri;
ENGINE
Type: Liquid-cooled 4-stroke Unicam 16-valve 76° V4
Displacement: 1,237cc
Bore x Stroke: 81mm x 60mm
Compression Ratio: 12:1
Max. Power Output: 95kW / 7,750min-1 (95/1/EC)
Max. Torque: 126Nm / 6,500min-1 (95/1/EC)
FUEL SYSTEM
Carburation: PGM-FI electronic fuel injection
Throttle Bore: 44 mm
Air-cleaner type: Oil-permeated, viscous-type paper filter
Fuel Tank Capacity: 21,5 litres
Fuel Consumption: 16.3 km/l (Tested in D-Mode WMTC mode*)
ELECTRICAL SYSTEM
Ignition System: Computer-controlled digital transistorised with electronic advance
Ignition Timing: 8.4° BTDC (idle speed)
Sparkplug Type: NGK: IMR8E-9HES DENSO: VUH24ES DENSO: VUH24ES
Starter: Electric
Battery Capacity: 12V/11.2AH (YTZ14S)
Headlights: Hi 55W / Low 55W
DRIVETRAIN
Clutch: Wet, multiplate *Wet, multiplate, hydraulic 2-clutch
Clutch Operation: * D mode/S mode/Manual mode
Transmission Type: 6-speed
Primary Reduction: 1.738 (73T / 42T)
Gear Ratios
1 2.600 (39T / 15T) *2.250 (36T / 16T)
2 1.600 (32T / 20T) *1.700 (34T / 20T)
3 1.260 (29T / 28T) *1.304 (30T / 23T)
4 1.076 (28T / 26T) *1.107 (31T / 28T)
5 0.961 (25T / 26T) *0.967 (29T / 30T)
6 0.897 (35T / 39T) *0.886 (31T / 35T)
Final Reduction 2.699 (37/39 x 19/17 x 28/11) * 2.706 (39/41 x 19/17 x 28/11)
Final Drive: Enclosed shaft
FRAME
Type: Diamond; aluminium twin-spar
CHASSIS
Dimensions (LxWxH): 2,285mm x 915mm x 1,335mm (w/ std screen and std position)
Wheelbase: 1,595 mm
Caster Angle: 28°
Trail: 107 mm
Turning Radius: 2.7 m
Head turning angle: 40°
Seat Height: 850mm
Ground Clearance: 180mm
Kerb Weight: 275kg (F: 132kg; R: 143kg)
* 285kg (F: 138kg; R: 147kg)
SUSPENSION
Type
Front: 43mm inverted telescopic forks with hydraulic damping, preload and rebound damping adjustment
Rear: Pro-Link with gas-charged damper, preload and stepless rebound damping adjustment
WHEELS
Type
Front: tubeless spoked
Rear: tubeless spoked
Rim Size
Front: 19M/C x MT2.50
Rear: 17M/C x MT4.00
Tyre Size
Front: 110/80-R19
Rear: 150/70-R17
Tyre Pressure
Front: 250kPa
Rear: 290kPa
BRAKES
Type
Front: Dual 310mm disks, Combined ABS
Rear: Single 276mm disk, Combined ABS *DCT version
Fotolar;
Bu da kendisiyle ilk haşır neşir oluşum
Unutmadan... Geçtiğimiz hafta teslim alan birine kaça aldığını sordum 36000TL olduğunu söyledi...
Teknik Özellikleri;
ENGINE
FUEL SYSTEM
ELECTRICAL SYSTEM
Starter: Electric
DRIVETRAIN
Gear Ratios
FRAME
CHASSIS
Wheelbase: 1,595 mm
Caster Angle: 28°
Trail: 107 mm
Seat Height: 850mm
SUSPENSION
Type
WHEELS
Type
Rim Size
Tyre Size
Front: 110/80-R19
Rear: 150/70-R17
Tyre Pressure
Front: 250kPa
Rear: 290kPa
BRAKES
Type
Fotolar;
