- 26 Mar 2006
750 lik shadowun spor modeli
Bence 600 lük bir model olsa daha iyi olurdu
http://www.honda.com.tr/motosiklet/content/modeller/custom/vtspirit.htm
ENGINE
Engine Type 745cc liquid-cooled 52-degree V-twin
Bore and Stroke 79mm x 76mm
Compression Ratio 9.6:1
Valve Train SOHC; three valves per cylinder
Induction Single 34mm constant-velocity carburetor
Ignition CD with electronic advance, two spark plugs per cylinder
DRIVE TRAIN
Transmission Wide-ratio five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41mm fork;4.6 inches travel
Rear Suspension Dual shocks with five-position spring preload adjustability;3.5 inches travel
Front Brake Single 296mm disc with twin-piston caliper
Rear Brake 180mm Drum
Front Tire 90/90-21
Rear Tire 160/80-15
DIMENSIONS
Rake 34-degree 30'
Trail 158mm (6.2 inches)
Wheelbase 65.0 inches
Seat Height 25.7 inches
Curb Weight 553 pounds
Fuel Capacity 3.7 gallons, including 0.9-gallon reserve
OTHER
Emissions Meets current EPA standards. California version meets current CARB standards and may differ slightly due to emissions equipment
Available Colors Black, Metallic Silver, Candy Dark Red/Flame, Ultra Blue Metallic/Flame, Metallic Silver/Flame
Model ID VT750C28
FACTORY WARRANTY INFORMATION
1 year Coverage of defects in materials and workmanship
By harbiturk
ENGINE
DRIVE TRAIN
Final Drive Shaft
Front Tire 90/90-21
Rear Tire 160/80-15
DIMENSIONS
Rake 34-degree 30'
OTHER
Model ID VT750C28
By harbiturk
