2004-2005-2006 rr kasa farklılıkları ???
30 Nis 2007
Arkadaşlar merhaba,
merak ettiğim bir şeyi sizlerle paylaşmak istedim 04-05-06 yllarında üretilmiş 600 rr ların kasalarında ne gibi farklılıklar vardır? bildiklerinizi yazarsanız sevinirim teşekkürler
23 May 2007
google sorsan söylerdi :pale:
2004 'te ek renk seçeneği olarak metalik maviyi çıkarttılar sonra iptal ettiler.
2005 ' tribal 600rr diye bi renk çıkarttılar birde movistar 600rr ilk bu yıl çıktı sanrıım
2006 turuncu 600 rr yaptılar..
bunlarda 2007 ler
23 May 2007
2004 teknik detaylar
General information
Model: Honda CBR 600 RR
Year: 2004
Category: Sport
Rating: 77 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 599.00 ccm (36.55 cubic inches)
Engine type: In-line four
Stroke: 4
Compression: 12.0:1
Bore x stroke: 67.0 x 42.5 mm (2.6 x 1.7 inches)
Fuel system: Injection
Valves per cylinder: 4
Fuel control: DOHC
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Chain
More details Consult a Honda repair manual.
Physical measures
Seat height: 820 mm (32.3 inches) If adjustable, lowest setting.
Wheelbase: 1,389 mm (54.7 inches)
Chassis and dimensions
Rake (fork angle): 24.0°
Trail: 95 mm (3.7 inches)
Front suspension: 45.0mm HMAS cartridge fork with spring-preload, rebound- and compression-damping adjustability
Front suspension travel: 119 mm (4.7 inches)
Rear suspension: Unit Pro-Link HMAS single shock with spring-preload, rebound- and compression-damping adjustability
Rear suspension travel: 119 mm (4.7 inches)
Front tyre dimensions: 120/70-ZR17
Rear tyre dimensions: 180/55-ZR17
Front brakes: Double disc
Front brakes diameter: 310 mm (12.2 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Other specifications
Fuel capacity: 18.16 litres (4.80 gallons)
Reserve fuel capacity: 3.40 litres (0.90 gallons)
Color options: Black/Silver, Candy Blue, Red/Black
General information
Year: 2004
Category: Sport
Stroke: 4
Compression: 12.0:1
Fuel control: DOHC
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
2005 teknik detaylar
Year: 2005
Category: Sport
Rating: 76.8 out of 100. Show full rating and compare with other bikes
Stroke: 4
Compression: 12.0:1
Fuel system: Injection. Dual Stage Fuel Injection (DSFI)
Fuel control: DOHC
Ignition: Computer-controlled digital transistorized with three-dimensional mapping
Starter: Electric
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 163.7 kg (361.0 pounds)
Wheelbase: 1,384 mm (54.5 inches)
Front suspension: 41.0mm inverted HMAS cartridge fork with spring-preload, rebound and compression-damping adjustability
Rear suspension: Unit Pro-Link HMAS single shock with spring-preload, rebound and compression-damping adjustability;
Rear suspension travel: 130 mm (5.1 inches)
Front brakes: Double disc. 4-piston calipers
Color options: Black, Black/Tribal, Metallic Silver/Black, Red/Black
Comments: Model ID: CBR600RR
2006 teknik detaylar
General information
Year: 2006
Category: Sport
Rating: 74.6 out of 100. Show full rating and compare with other bikes
Stroke: 4
Compression: 12.0:1
Fuel control: DOHC
Starter: Electric
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Color options: Black, Pearl Orange/Black Tribal, Light Silver Metallic, Red/Black
GKN
6 Mar 2006
hmm..
07 de bi deişilklik var ama dimi
155 kg a düştü diye duydum
10 Kas 2006
2003ve 2004'ün , 2005 ve 2006'dan en büyük farkı up-and down ön amörtisörler ve yanılmıyosam mapping değişiklikleri.
